Tesla Roadster: an electric car with a diesel generator
Discussion in 'News' started by TEG, Nov 14, 2007.
Tags:
  1. mt2
    mt2 Member
    Chicago Area, North Burbs
    Seems like kind of a strange "oops" on Tesla's part. I understand why they would take a generator with them. But it would seem like Alice's Restaurant is getting a bunch of free press out of the test drives. You'd think they'd spring for a 220 connection.
  2. SByer
    SByer '08 #383
    Cupertino, CA
    So, when I drove, they were parked across from Alice's. Also, not sure a 220V would be "reasonably" accessible - or worth the significant bother every time they have to hook up. Plus, that's not the only location they take the trailer for test drives. So, while using a generator isn't "ideal", it's understandable.
    -Scott
  3. vfx
    vfx Well-Known Member
    CA CA
    Charging with a generator has certain requirements. Has anyone spec'ed out what the Electric car wants?
    Grounding? Noise? Clean output?
    A Honda Put-Put VS a commercial tow plant each have many differentiating qualities even the ones for construction VS studio (movie) lighting.
    What about sinewaves, sinusoidal and square, harmonic distortion, inverter types, etc. etc.
  4. hcsharp
    hcsharp Active Member
    Vermont
    I've never been able to charge from a generator and haven't known any Roadster owners who were successful in their attempts. However, at an EV event last fall there was a guy who was selling an inverter system that connected to a Prius battery so you could use your Prius for backup power. He wanted to prove it would charge my Roadster and I was somewhat doubtful. But it worked! We left it connected for almost 2 hours at 115v, 16A before I had to leave. He said it produced a "perfect sine wave" and I noticed the voltage remained very stable which is usually not the case with most generators. So I can't answer your question exactly but I know it has to be a sine wave without too much harmonic distortion or voltage fluctuation.
  5. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I have a Xantrex Prosine inverter in my truck. It will allow charging up to 20 amps. They are a little more expensive, but it gives clean power and will change an EV.
    http://www.xantrex.com/power-products/power-inverters/overview.aspx
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Transport Canada reportedly tried six different generators and none worked. Sounds like it needs stable voltage, negligible harmonics, and stable frequency.
  7. vfx
    CA CA
    I never noted what kind of genny Tesla used back in the day (upthread) but I did find this page that goes into generator detail. It's talking about production lighting but it's still pretty thorough.
    ScreenLight & Grip's E-Newsletter.
  8. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    Tesla's predecessor, AC Propusion's T-zero, had a trailer genset built from a Kawasaki motorcycle engine. There are several web pages about it:
    Genset trailer - Wikipedia, the free encyclopedia
  9. TEG
    TEG TMC Moderator
  10. vfx
    CA CA
    Yes there is a towable genny thread. I just wanted to focus on stationary generators and what characteristics they must have to charge an EV regardless of size.
  11. TEG
    TEG TMC Moderator
    Ingineer/Phil's doubles as a stationary generator. It is designed as a portable self fueled (by propane) CHAdeMO QC for events and such, but doubles as a range extender when he needs to get to some event further than the usual LEAF range.
  12. VolkerP
    VolkerP EU Model S P-37
    Germany
    Nice find! From the article:
    Sooo - the neighbors wouldn't be amused with a Diesel genset, but a pickup truck is OK?
  13. daniel
    daniel Active Member
    Spokane, WA
    Most folks don't leave their diesel pickup truck running at full throttle in the driveway for half an hour to an hour, and if they do, the neighbors probably would be very annoyed. I hate the noise of lawn mowers, and I'll bet a diesel genset would be a lot worse.
  14. NigelM
    NigelM Recovering Member
    Northern Virginia
    Thanks to our friends at AAA:
    First Electric Vehicle Charging Truck Put Into Service in LA
    And Green Charge Networks:
    EV Roadside
  15. vfx
    CA CA
  16. doug
    doug Administrator / Head Moderator
  17. tdelta1000
    tdelta1000 Active Member
    South Florida
    The use of the diesel generator is a smart choice on the part of Tesla Motors... It provides a good way to charge the test drive cars when electricity is not available, it has a lower noise output over a gasoline generator and ease of transport in the Ranger vans. An other option could have been a LPG (Liquid Propane Gas) generator.
    I think TM could fully build out their Ranger vans with a solar system on top of the trailer which stores power in a battery backup and a generator system as a backup in the future if the generator is a problem for some.
  18. Dave EV
    Dave EV Active Member
    San Diego
    TonyWilliams had a 56kW diesel generator at a LEAF meeting the other month to show off Andromeda Power's portable QC stations. The noise from the generator was much more pleasant than your typical lawn mower.
    Pics starting at this post: My Nissan Leaf Forum View topic - San Diego Meet, June 14 ?????
    PriUPS concept is the way to go - how much power can they handle? A good 240V inverter plugged into the batteries at 16A would be a LOT better than the 120V/16A mentioned.
