http://green.autoblog.com/2011/02/16/gms-bob-stempel-talks-about-lithium-batteries-and-what-will-maWhat about Tesla's pack, which uses 6,000-plus laptop computer batteries wired together in series and in parallel? How can they make – and service – something like that cost effectively? "Their people came from the computer business, and they certainly had the capability to put together an algorithm to control that. But that's too many cells. I think over time, we'll see them shift to a more conventional kind of pack."
Yet Mercedes is using Tesla batteries in its test fleet, and Toyota has partnered with Tesla. "The Toyota/Tesla partnership arose out of a series of other issues. It was really a convenient marriage for Toyota, because they needed to do something with the Fremont plant. When you unravel that story, there's a lot more to it than just batteries. And Mercedes has sold off part of their investment and is backing away from that. That multi-cell concept is very, very difficult, so I think you'll see Mercedes moving toward bigger cells and fewer of them. They wanted to get their feet wet on an experimental basis so were trying a little of everything.
I don't believe that the temperature control is overkill if you are going to consistently charge this pac using a DC fastcharge system and keep all the parametes for the pacs under proper conditions. Watch what happens to the non-liquid cooled cars that try to charge an aging pac quickly. I predict a couple of fires!
Other packs can be mounted in similar fashion. The LEAF pack is in the bottom of the vehicle.The form factor will also be allowing the Model S to have a lower center of gravity and stiffer body than the competition.
A123 would be much more expensive at the cell level since they don't have anywhere near the volume or years of working with the form factor. The cells are also not as energy dense as the LiCo cells, but they have much better power and lower internal resistance values so they heat up much less. They also don't have the thermal runaway issues that LiCo has, so they could probably get away without any active cooling, and some simple resistance heating should be enough in lower temps.I can only wonder at the cost of 90 kWh battery from system a123. Would it have the form factor ( flat )? Would it require heating and cooling?
I would not recommend fast charging any battery pack consistently other than an Altairnano pack, (which Proterra does on a daily basis in their buses). Fast charging should only be an occasional occurrence if you want your pack to last. Other chemistries, LiMn, LiFePO4, have less of an issue with thermal runaway than the LiCo that Tesla uses.I don't believe that the temperature control is overkill if you are going to consistently charge this pac using a DC fastcharge system and keep all the parametes for the pacs under proper conditions. Watch what happens to the non-liquid cooled cars that try to charge an aging pac quickly. I predict a couple of fires!
I can think of good reasons to go overboard, warranty issues and safety issues. I'm sure they did a cost benefit analysis and decided better safe than sorry. It's a good business practice. My hope is that with time, and possibly with better cells, they can at least reduce the energy used for cooling during a charge. A 25% charging loss does not help to make the case for EV's.Yea, I'm not a lithium battery researcher, but I find it hard to believe Tesla would intentionally go way overboard in a non-profitable fashion. They've had years to gather numbers from actual field use, more than anyone else. I can respect the researcher, but I'd think it's more likely he's missing data about why Tesla found the solution useful.
I don't know where you get your info from, but the Roadster gets comparable mi/kwh (wall to wheel) with the Leaf when both are driven conservatively. In cold weather, I bet the Leaf gets substantially worse numbers.I can think of good reasons to go overboard, warranty issues and safety issues. I'm sure they did a cost benefit analysis and decided better safe than sorry. It's a good business practice. My hope is that with time, and possibly with better cells, they can at least reduce the energy used for cooling during a charge. A 25% charging loss does not help to make the case for EV's.
True, but no one has such a thin yet energy dense pack. That Model S pack is truly amazing, ideal packaging.Other packs can be mounted in similar [i.e. low] fashion. The LEAF pack is in the bottom of the vehicle.
I can think of good reasons to go overboard, warranty issues and safety issues. I'm sure they did a cost benefit analysis and decided better safe than sorry. It's a good business practice...
It is good practice and Tesla was certainly very careful in the beginning. Martin (or someone) said that they worried if they ended up having a fire, it would set EVs back again by years.There were many "overdesigned" features on the first Roadster. The charger originally came with a fire detector and had several shutoff features that have been eliminated.
I get my numbers from people on this board. Miles/kwh takes into account vehicle efficiency, I'm talking strictly charging efficiency. 25% loss is terrible.I don't know where you get your info from, but the Roadster gets comparable mi/kwh (wall to wheel) with the Leaf when both are driven conservatively. In cold weather, I bet the Leaf gets substantially worse numbers.
How so? Have any LEAF packs been damaged from overheating?From all of the reading and research I have done about both vehicles, Elon may turn out to be right in his "primitive battery pack" statement.
Yes the density of LiCo is superior.True, but no one has such a thin yet energy dense pack. That Model S pack is truly amazing, ideal packaging.
Totally agree.It is good practice and Tesla was certainly very careful in the beginning. Martin (or someone) said that they worried if they ended up having a fire, it would set EVs back again by years.
