Tracking 3 OEM Brakes
I want to track my 3 for fun, but want to know the limitations of the OEM brakes on the LR. For those that have, how did the brake hold up? Did the rotors warp, brakes fade or fail? I want to go hard, but if my brakes can't handle the truth, I'll take it easy on the brakes.
Can we assume you'll swap in track pads and DOT4 fluid? Or are you looking to use the 100% stock setup on the track?
Like most cars, the Model 3 doesn't come with track pads or fluid from the factory... (Not the M3P brakes either btw)
I’m running stock rotors for now, and no warpage after 5 HPDE events. Running track pads, fluid, lines, etc. the open back design of those calipers look great for changing pads out. I assume it can be done without removing the caliper. Please be careful and definitely do fluids and higher temp pads
