Note: This feature currently requires accessing the site using the built-in Safari browser.
after several VWs and Audis with oil leak/seepage and oil burning were enough for me to stay away from any ICE cars.
highly not true. Even VW/Audi dealers/mechanics said seepage is normal for their cars, which is far too common among the German cars.I've had the opposite experience. I've owned several Audis (and still own one today) and haven't had a single problem with oil leaks and/or burning. In fact, my cars have been bulletproof. And that's saying a lot since mine have been fairly highly modified.
Your other posts about needing to drive a couple of miles before the oil circulates through the vital engine parts and turbocharger is pure nonsense. I wasn't going to respond when you first posted that nonsense a few months ago, but you keep repeating it like it's some kind of fact when it's not. Today's oil is very thin and the low viscosity means that it's flowing easily in mere seconds, even in cold temps. Because my car is modified, I monitor both oil temps and coolant temps in my Audi, as well as oil pressure, so I know exactly when I can drive the car hard without any worries. Also, it does zero damage to idle an ICE. It's not the most friendly thing to do to the environment because of emissions, but it does no damage whatsoever to the engine.
Flowing through the system in seconds doesn't mean that the car is ready for the peak/best performance and reliabilityToday's oil is very thin and the low viscosity means that it's flowing easily in mere seconds, even in cold temps.
I don't think you know when to drive your car hard since you said your car will be "Ready" in seconds you start the engineBecause my car is modified, I monitor both oil temps and coolant temps in my Audi, as well as oil pressure, so I know exactly when I can drive the car hard without any worries.
I specifically stated in my previous posts that idling longer period of time and frequent idling will harm the internal parts,it does zero damage to idle an ICE.
Engine oils have different viscosity and operating temperature ratings, and high performance turbocharged cars require higher viscosity and higher grade oil due to the higher operating temperature. Those types of oils are thicker and slow to flow through the system.
The argument here is not the viscosity. any oil needs to be warmed up to reach the optimal operating temperature for the best performance and reliability.The newer VW/Audi turbocharged engines use a synthetic 0W-20 oil, so it's pretty thin (most likely for improved fuel economy).
I've never had an issue with oil seepage/leakage in the 6 Audis I've owned, but I don't keep them past the warranty period either...![]()
I call your statement BS on 6 previous of your Audi's having no oil leak/seepage issue. I just called my friend who is a service advisor for an Audi dealership in DC and he told me that it is extremely rare to see the cars with no oil leak/seepage.
Try Google search "Audi Oil Leak" and you will not be able to go through the entire list within a day.
Thanks for the great writeup and fair comparison. Very few of us will ever go back to an old-fashioned piston slapper so it's interesting to get an occasional glimpse over the fence.
Driving an Audi doesn't make me a "car guy". You know what does make me a car guy though? I'll tell you--first, I'm an enthusiast who modifies and races his cars. Secondly, I've been wrenching on cars since I was 15 years old. In fact, I attended school for automotive technology and actually worked as an automotive technicians for many years, working my way up to ASE Master Technician. I've rebuilt engines and transmissions with my own hands. Then I got into automotive engineering and specialized in lubrication systems. So yeah, I'm about as much as a car guy as someone can be. Today, I'm in management at an engineering company.highly not true. Even VW/Audi dealers/mechanics said seepage is normal for their cars, which is far too common among the German cars.
Also, you don't know about the performance side of the "car" that requires the optimal oil temperature for the best performance of the cars, especially turbo charged engines. driving an Audi doesn't make you a "car guy".
Engine oils have different viscosity and operating temperature ratings, and high performance turbocharged cars require higher viscosity and higher grade oil due to the higher operating temperature. Those types of oils are thicker and slow to flow through the system. Sure it will not kill the engine right away, but it will accelerate the wear and tear and even hurt the turbochargers if you start the car and floor it right away without warming up the engine to bring up the oil temperature up to the level. You can simply drive gentle during the first 2-4 miles and your engine oil temperature should be at the optimal operating temperature.
I am not even sure why you are so worked up and unhinged by my posts, but let me explain by pointing out your wrong statements:
How Much Gas Does Idling Waste?
Serious implications arise from excessive engine idling including increased fuel consumption, and shorter vehicle life. Learn 5 solutions to reduce idling.www.verizonconnect.com
