Turn off climate in camp mode?
I would like to keep the 12V circuit running to power a Dometic refrigerator while camping. From what I can tell, the only way to do this is with camp mode. But that keeps the climate running, which will probably waste a lot of power. Is there any way to turn off climate control and keep the 12V on?
I will be parked in a location with large temperature swings throughout the day, from 35 - 80°F. So any set point on the thermostat would probably run either the heat or the AC.
I’ve read some reports that Sentry mode will also keep the 12V on, although older posts say the opposite. Perhaps this was changed in a software update. If this works, then I guess Sentry might draw less power than camp mode. Has anyone measured the difference?
Upvote 0
Depending on the Dometic model...
Mine does not use that much power. The new model S delivers around 16V (not 12). And so my Dometic only draws around 4Amps. Therefor I use the ODB-2 connector is the driver's footwell. That delivers a constant power source and should be able to handle 5A. (I did that in my 2017 Model S to. That ODB delivers 10A, of memory serves me right.)
Upvote 0
