Turned on the Solar and see potential issues. Please help validate
dgtron
New Member
Feb 10, 2024
2
0
60008
I got the approval to power on yesterday & I turned on the system and have been exploring.
I have 2 x 7.6kw inverters & 46 400 w panels installed by Tesla. When I log into the inverter I see String 2: Small voltage & no MCI detected.
Here is the wiring diagram
Looks like String 2 which has 20 panels on the right is not wired in correctly. Is this right? What is the process to bringing this to Tesla's attention is yes? Considering the dreaded customer service Tesla has, I 'm sweating on this issue.
Thank You! Makes perfect sense now.
I have 2 inverters 7.6kw each. Do the inverter connect with each other in parallel? The number in each string seems very similar or is it exclusively for that set of panels?
