Brother has the same car
If you go into ur Display settings in the car and go down to energy, there's 3 displays the percentage, distance, and when you click distance it shows rated or ideal. Rated will show you the range based on the rate that you drive with. Ideal will show you the range if you were driving at around 240 wh/mi. Most of the time you won't get ideal and your "rated" range will be much more accurate
