As a start, here is a list of acronyms I gathered recently from the service manual and other sources. This includes several internal module names that may not appear often in this forum; it also includes a few generic terms not specific to the Roadster.
ABS Anti-Lock Brake System
ACC Accessory
APS Auxiliary Power Supply
AUX Auxiliary
BMB Battery Monitoring Board
BPS Backup Power Supply
BSM Battery Safety Monitor
CAN Controller Area Network
CSB Current Sensor Board
DFC Dual Fan Controller
DMC Digital Motor Controller
ESS Energy Storage System
FW Firmware
GPS Global Positioning System
HCS High-power Charging System
HPC High Power Connector
HVAC Heating, Ventilation and Air Conditioning
HW Hardware
IP Instrument Pack
LHD Left-Hand Drive
MC120 Mobile Charge cable 120V
MIL Malfunction Indicator Lamp
NTC Negative Temperature Coefficient
NVH Noise Vibration Harshness
OBDII On Board Diagnostics (2nd edition)
OBM On Board Monitoring
PEM Power Electronics Module
PTC Positive Temperature Coefficient
RHD Right-Hand Drive
RKE Remote Keyless Entry
SHFT Button shift module
SOC State Of Charge
SRS Supplementary Restraint System
SWP Switchpack
TC Traction Control
TCM Transmission Control Module
TIN Tire Identification Number
TP Throttle Position
TPMS Tire Pressure Monitoring System
TXV Thermostatic Expansion Valve
VDS Vehicle Display System
VMS Vehicle Management System
VMSIO Vehicle Management System Input/Output
