Yes, a Model 3 LR RWD can theoretically do 641 mi/hr at 150kW. It’s a straight calculation from the power indication. For a 3 LR RWD, the multiplier is 4.272 mi/hr / kW.Highest we got was 613mph. Has anyone seen higher on a V2 charger?
Lol this was at 105 degrees. I live in AZ so I’m used to super high temps.Try charging in triple digit heat in the desert - you'll see the charge rates cut in half or more because of connector temperatures.
I can't wait to have liquid cooled charge cables for hot summer locations...
Lol it’s more like it’s not really needed cause the car charges so fast already but don’t get me wrong I’m totally down for a 40% improvement.V3 not needed? Why not - 150 kw is 40 percent slower than 250kw.
We have seen 624 mph. And your right any faster and I will not have time to wolf down lunch.View attachment 426976 this week we traveled to Cali and the car was always ready before we were. We routinely were seeing high 500’s for mph. Highest we got was 613mph. Has anyone seen higher on a V2 charger?
It was above 100Kw for a good amount of time. Compared to my S last summer the 3 can run laps in terms of charging speeds. At like 90% battery I think I was still getting like 60kw.Well, I've had several disappointingly slow sessions in triple digits recently that I was pretty sure were because of the temps. How long did it hold the 144?
We just completed a 3300 mile round trip from Austin to Philadelphia with 15 supercharging stops and five nights of hotels with destination charging. I routinely got 144 kW charging until about 50%, and the car was always ready before we were finished eating. Supercharging is dramatically faster now than when I had a S 60 that peaked at 90kW for a brief time.Well, I've had several disappointingly slow sessions in triple digits recently that I was pretty sure were because of the temps. How long did it hold the 144?
How full were the chargers? Even at quartzite being completely full I was still pulling about 96kw at its peak.That sounds like what I was seeing last week, but not for three desert heat stops in a row on Monday and Tuesday.
Another thing to keep in mind that makes your thread title incorrect. Pull in and all the A's are taken and you must share. You then will only get dregs and could be getting 20kW. With V3 there is no A/B sharing and you can get up to 250kW even if you get the last stall.Lol it’s more like it’s not really needed cause the car charges so fast already but don’t get me wrong I’m totally down for a 40% improvement.
A lot of people will be excited because "250kW" seems so much faster than "150kW", but the reality is that the charging time will be less than 5 minutes faster. The biggest benefit from V3 stations, especially in hot climates like AZ, will be the consistent charge power due to the cooled cables in addition to not having to share power between stalls.Lol it’s more like it’s not really needed cause the car charges so fast already but don’t get me wrong I’m totally down for a 40% improvement.
Yeah not sure, when I got 143kw it was like 105 degrees outside and the handle about burned my hand off unplugging it from car.I wasn't sharing a charger stack in any of these cases.
We know that worn plug ends will produce this effect, so it's possible I had bad luck repeatedly. But since the temps were consistently higher, I assumed that was the driver.
