I just wanted to warn everyone, the hatch due to its length and size actually extends pretty high into the sky, ESPECIALLY if you have the spoiler, that adds like 2". I had a 2017 Honda CRV before this and I could have the hatch lift and still walk under it and I am 6'2" while my car was in the garage and the garage door was open above the car. With the Model Y its pretty bad, luckily the spoiler didn't hit the garage door while it was first opened, but it was damn close, like 1/2"! Be very very careful the first time you open it with your garage door open, especially as garage doors usually have hinges and handles etc on the back side that are exposed when its in the open position. Make sure you set your hatch height correctly so no matter where the car is, it won't hit anything. When I did that I really have to duck to get under the hatch unfortunately, was really hoping it would be more like my CR-V where I could fit under it while its open
Here are some measurements for you all. I have what I would consider a normal garage door, modern house, built 10 years ago, so nothing super unique.
Distance from ground to lowest point on garage door when in open position, 7' 2"
Distance I had to set the hatch too from the ground to the bottom of the latch on the hatch, 5' 5" (give about 1-2" of clearance from spoiler to lowest point on garage door when its opened).
So I would have needed another 9" in order not to hit my head (again I am 6'2"). Not fun and have already hit my head a few times
Because of that I have done this, see below... might have to add even more foam tape along the length of the inside panel.
