Because I’m charging to 100% tonight when I checked Sarn was beyond my range.
May also change en-route e.g. if you hit traffic / roadworks an "unreachable" Supercharger might fall into range
Generally speaking not worth slowing down [to have greater range] for a more distance Supercharger, overall trip will be shorter if you drive-faster and charge-longer (assumes free stall when you get there ...), similarly no point slowing down to charge-less at Supercharger (that will save you some money though ...)
But of course you can't do anything about slow traffic / roadworks, so when that happens it can create an option for a more distant Supercharger
If you are on your last-leg before home then slower, more range, is usually the best option (allowing that it is likely to add 5 minutes to get into service centre, plug-in, power ramp-up, disconnect, re-join highway)
Slowing for more range to avoid a detour to off-route Supercharger may be worthwhile. I have a trip where I have always made it to the out-of-range, on-route, Supercharger where SatNav tells me I need a 15 minute off-route detour (and extra Juice to make up for the extra miles). Traffic, drafting a truck (at safe distance), and doing a 50-stretch sort that. Adds less than 10 minutes to my journey time and saves around 20 minutes.
Some (Most?!!) of that will depend how nerdy you are.
