Tips:
- Help ensure the battery is warm by selecting the SC on the nav, which will turn on On-Route Battery Warmup
- Charge when the ambient temperature is not hot (cooler is better)
- Charge on a stall that hasn't been recently preheated by a previous car (admittedly, this is hard to tell, see #5)
- Don't use a shared stall at a V2 station
- Try another stall
Thank you, Zoom. We also have a 2014 S85 that we purchased new. I have Supercharged that car probably 300 times on many road trips, so I am quite familiar with #4. Regarding number 5, well, around here anyway, multiple unpaired stalls are not common throughout much of the day. Moving to a new stall is just using the guess-o-meter to see whether the paired car is deep into the taper or still pulling 100+kW. I am unclear about #1. I know where the Supercharger is and I loathe using navigation, especially when I know where I am going. About #2, guess I will try charging around 3AM when the temperatures are in the 70s. (Not!)
I wish to thank those who have shared their rates. I guess I will have to let the battery deplete to around 30%, and then drive for 30 minutes out and about and try to plug in when the weather is not too hot to see what rate the car pulls.
If the problem is with the user, then again, thanks to all. If the problem is with the Supercharger location, I have no way of knowing. If the problem is with the car, I guess we are just SOL. Tesla does not do well with these sorts of problems. The touchscreen does not show the surrounding vehicles or the speed limit signs when out. The headlights are on during the day too. They are aware of this situation. Their company line is, "The next software update should fix those issues." Fifteen updates later, still zip.
Oh, to the inquiring mind, the battery was replaced because there was an issue with charging--I could not charge at 120/15; 120/20; 240/40 or Supercharge.
