I understand the difference between SSDs and MicroSDs. I was speaking to everyone and not just the OP.
I still do NOT recommend a SSD for TeslaCam or Sentry usage due to their lower temperature range:
Non-Operating Temperature (from -20 degrees Celsius to +70 degrees Celsius), Operating Temperature (from 0 degrees Celsius to +45 degrees Celsius)
Operating temperature maximum (which means sentry is running) is 45 C = 113 F, which will easily hit on any warm day parked in the sun (I stated in my previous post that my car hits 160F on a 80F day). This is also taken from the
Portable Sandisk Extreme which is made for rugged and extreme temperatures. If you will only use the SDD for the dash cam feature, it will be fine since you are likely running the AC during the summer.
Even though SSDs and cheap usb drives will work, that doesn't mean it will continue to work for long periods of time. Telling people to use SSDs or cheap thumb drives just increases complaints about drive failure or missed footage later down the road (which has already started happening)
