Why does the Sentry Mode SSD get so damn hot? It doesn't get that hot plugged into the computer.
Can barely touch it.
Also, it's in a small enclosed space in the center console that doesn't get any air flow to aid in heat dissipation.It’s hot because it’s always in use saving the recent video clips when the Tesla is on. If you copied files using your computer to the same drive for 30-60 minutes straight, it would be hot as well.
But the OP is asking about an ssd. They're different, and don't normally get hot. Let's not confuse the issue.My USB thumb drive always gets mega hot. Does worry me a tad..
Most SSDs (unless older) use flash based memory so shouldn't read/write energy use be relatively about the same? Of course SSDs are usually in a larger area (especially 2.5") so waste energy (heat) dispersion should be a little better.But the OP is asking about an ssd. They're different, and don't normally get hot. Let's not confuse the issue.
Probably TeslaCam, not Sentry. TeslaCam is the one that constantly writes the recent videos whenever the car is on.
I was submitting my similar experience relating exactly to the OP's issue. USB storage flash RAM getting super hot. SSD vs thumbdrive are the same, just form factor.But the OP is asking about an ssd. They're different, and don't normally get hot. Let's not confuse the issue.
It’s best to use an SSD drive that is rated to withstand extreme temperatures since the cabin can get very hot at times. Those drives are generally designed to withstand the constant reads/writes associated with Dashcam activity too.
The memory chips used are similar, but not identical. The real difference is in the chip(s) used to control the in/out to the memory - flash drives use cheap chips that get hot fast. Ssd's typically use better chipsets that don't get as hot. It's the IO part of these devices that generate the most heat.Most SSDs (unless older) use flash based memory so shouldn't read/write energy use be relatively about the same? Of course SSDs are usually in a larger area (especially 2.5") so waste energy (heat) dispersion should be a little better.
What kind is it? Mine (a sandisk 250GB) just gets a little warm.
summer is right around the corner, so those of you using SSDs and cheap thumb drives might having failing drives soon when sentry mode is enabled due to the constant writing. Temperatures in the car can easily reach 160F+ inside your car with 80F weather outside.
I personally use a 128gb Samsung Endurance Pro thats rated for constant writes for up to 43,800 hours (5 years) and withstands operating temperatures ranging from -13F (-25°C) to 185F (85°C). I use it in conjunction with a usb A + usb C microSD adapter. They dont sell the one I use anymore but this is similar and great for those who have an Android phone with usb C. iPhone users can try this, but I havent tested it
They are so cheap now, no reason to get something else unless you want extra storage. Although western digital has their 256gb purple microSD which I may purchase for TeslaCam once it drops lower in price
