Wind noise from dash/windshield interface area
I have a noticeable amount of wind noise coming from the bottom of the windshield of my 2022 Model Y when driving above 50Mph.
if i cover the dash/windshield interface area with pillows, the wind noise goes away. I noticed both corners of the dash/windshield interface have clear visible holes which appear to be air gaps to frunk area. Photo below pointing to area in question.
Are these holes normal?
Could someone please check if you also see these holes in your cars? From inside of the car, the frunk area appears to be visible trough these holes.
I had to push the dash corner down a bit with my fingers to clearly see hole and take photos.
Thank you!
Reactions: GOVA
There have been a number of posts on the forums about this very common problem on the Model Y. Many brought it back to Tesla and it was repaired. I think they added foam and adhesive from the outside.
"They added some black foam insulation in that area. Not sure how they did it but they did."
Here is one of many forum posts:
And another forum post full of good info:
Reactions: GOVA
