Would 20x9 front and 20x10.5 rear wheels fit Model 3?
Discussion in 'Model 3' started by vitaliy, Feb 9, 2018.
Tags:
  1. vitaliy
    vitaliy Member
    Tysons, VA
    I found perfect set of wheels, but the store said that 20x9 front and 20x10.5 rear were not tested on the Model 3...
    And the tested sizes of 20x8.5 front and 20x10 rear aren't produced at all (for those wheels in particular).
    Please advise if 20x9 front and 20x10.5 rear would fit...
    PS: Really excited to get the car soon!
  2. tracksyde
    tracksyde Member
    So Cal
    Check out this thread over at M3OC:
    Model 3 Aftermarket Wheel Fitment
    9.5" in the front and 11" in the back sound do-able based on measurements made by @Mad Hungarian
    What are the offsets you're looking at?
  3. Daniel in SD
    Daniel in SD Member
    San Diego
    I couldn't see from the post what offset 9.5" wheel fit in the front?
    Time to spend the next six months looking at wheels. haha
  4. vitaliy
    vitaliy Member
    Tysons, VA
    Thank you!
    I'm not sure how it all works with offsets, but here is spec sheet:
    • Wheel Size 20x9 front and 20x10.5 rear
    • Offset 40mm front and 50mm rear
    • Bolt Pattern 5x114.3
    • Center Bore 73.1
  5. Mad Hungarian
    Mad Hungarian Member
    Montreal, QC, Canada
    These specs are fine, as long as the manufacturer can confirm the design in question fits over the brake calipers.
    Note that you will need centering rings to bring the center bore size down to 64.1.
  6. vitaliy
    vitaliy Member
    Tysons, VA
