Yep. I did exactly that. But you might want to hold off a little.
Something new/different might be coming and the retrofit to that might be different.
But if you still want the original EU-style tail lights:
You'll need two really long wires to run from each side repeater, through the frunk, through the firewall, through the cabin, then to the trunk.
Don't cheap out on the resistor. If you're stopped at an intersection, this resistor will need to dissipate all that power, because we need to trick the car that the brake lights are still working.
Here's my BOM from mouser, includes some excess in case of crimping screwups:
2x
1-1670921-1
TE Connectivity Automotive Connectors
2
571-1-2141520-1
2x
1-2141520-1
3
571-7-1452668-1-LP
12x
7-1452668-1 (Loose Piece)
4
571-1718760-1-LP
12x
1718760-1 (Loose Piece)
5
571-967067-1
10x
967067-1
6
571-967056-1
2x
967056-1
7
284-HS10270RJ
2x
HS10 270R J
Ohmite Wirewound Resistors - Chassis Mount
Then I basically made a dongle between the harness and the tail light.
