cloneguru
Who wants to take some guesses at what my issue is?
Current goal is to charge the pack, it's pretty low right now.
Just purchased a 2012 S P85 in non-running condition.
I know charge port door is physically corroded and the bottom pin is broken. I scraped some of the corrosion off for it to recognize the door is closed when it closes and if I apply some downward pressure above the top pin to offset the weight of the door, it opens when I tell the vehicle to unlock the door but does NOT light up. If I manually push the lock pin down, it will glow red but red is the only color I've seen the charge port glow to date.
Vehicle is unable to verify if the rear Electronic Parking Brake ( EPB ) is engaging. I'm guessing this has to do with it being towed with straps holding onto rear left wheel A-Arm.
All Fuses test OK
I'll happily test any ground studs if I know where to find them. The frunk is currently fully exposed and easy for me to access the majority of components.
All Fuses test OK
Code:
CHG_w108_cpCoverOpen (hidden)
audience:[no audience]
2:CHG_w108_cpCoverOpen
3:CHG_a108_cpCoverClosed=--
CHG_a108_coverTimer=--
CP_w009_coverOpen (Unable to charge/Use Mobile App to schedule service)
audience:[customer, service-fix, factory]
2:CP_w009_coverOpen
3:CP_a009_cover1OpenCounts=--
CP_a009_cover2OpenCounts=--
CP_a009_cover1Open=--
CP_a009_cover2Open=--
BMS_w107_SW_Cell_Voltage_Sensor (Vehicle may not restart/Service is required)
2:BMS_w107_SW_Cell_Voltage_Sensor
3:BMS_a107_bmbID=--
BMS_a107_tvshLeadIndex=--
BMS_a107_tvshImpedance=--
BMS_a107_moduleV=--
BMS_a107_brickSumV=--
BMS_a107_errorType=--
BMS_w129_SW_BMB_VSH_Connector (hidden)
audience:[service, factory]
2:elevated voltage sense harness resistance
3:BMS_a129_bmbID=--
BMS_a129_r0=--
BMS_a129_r1=--
BMS_a129_r2=--
BMS_a129_r3=--
BMS_a129_r4=--
BMS_a129_r5=--
BMS_a129_r6=--
BMS_w164_SW_Brick_SOC_Imbalance (hidden)
2:SOC Imbalance exists between bricks associated with a single BMB.
3:BMS_a164_intraBmbSOCImbalance=--
BMS_a164_bmbID=--
BMS_a164_maxBrickSOCID=--
BMS_a164_minBrickSOCID=--
BMS_a164_maxBrickSOC=--
BMS_a164_minBrickSOC=--
BMS_w166_SW_AhToBeCharged_Imbal (hidden)
2:AhToBeCharged Imbalance exists
battery pack may be poorly balanced.
3:BMS_a166_ahToBeChargedImbalance=--
BMS_a166_maxAhToBeChargedBrickID=--
BMS_a166_minAhToBeChargedBrickID=--
BMS_a166_maxAhToBeCharged=--
BMS_a166_minAhToBeCharged=--
BMS_u008_limpMode (Acceleration and top speed reduced/Performance may be restored on next drive)
audience:[customer]
2:to do
3:none
GTW_w017_accLoadShed (Electrical system power reduced/Vehicle may shut down unexpectedly)
audience:[customer, service]
2:GTW_w017_accLoadShed
3:none
GTW_w018_hvacLoadShed (Electrical system power reduced/Vehicle may shut down unexpectedly)
2:GTW_w018_hvacLoadShed
3:GTW_a018_ibsVoltageFiltered=--
GTW_a018_12VState=--
GTW_a018_accRailReq=--
GTW_a018_accRailIsOn=--
GTW_a018_hvacRailReq=--
GTW_a018_hvacRailIsOn=--
GTW_a018_hvacLoadShedType=--
GTW_a018_driveRailReq=--
GTW_a018_driveRailIsOn=--
GTW_w343_frunkLatchFailure (Unable to confirm the hood latch is closed/Open and securely close the hood before driving)
2:GTW_w343_frunkLatchFailure
3:none
GTW_w384_disableKeepAwakeSupport (hidden)
2:GTW will not use keep awakes as a reason to request 12V battery support from the BMS
3:none
GTW_w405_12VNotSupported (hidden)
audience:[service-fix]
2:GTW_w405_12VNotSupported
3:GTW_a405_dcdcTargetVoltage=14.0000
GTW_a405_dcdcEnableOn=1.00000
GTW_a405_bmsDcDcEnable=0
GTW_a405_ibsVoltage=11.5000
GTW_a405_revBattFault=0
GTW_a405_dcdcEfuseEnabled=0
GTW_a405_dcdcOutputVoltage=--
GTW_a405_dcdcEfuseFaulted=0
GTW_a405_ctrsClosed=0
GTW_a405_dcdcOutputCurrent=--
GTW_a405_w370=0
GTW_a405_w174=0
GTW_a405_can2BusOff=0
GTW_a405_12VState=12VNOTSUPPORTED
GTW_a405_bmsState=FAULT
GTW_a405_can1BusOff=0
GTW_a405_bmsMIA=0
GTW_a405_dcdcMIA=0
GTW_a405_f210noSupportAllowed=0
GTW_a405_inServiceMode=0
GTW_a405_inTransportMode=0
GTW_a405_inFactoryMode=0
GTW_u019_overheatSocTooLow (Cabin Overheat Protection disabled/Battery charge level too low)
audience:[customer]
2:Can't protect cabin overheating - SOC Too Low
3:none
ESP_w002_espFaultLamp (Stability control disabled/Drive with caution)
audience:[customer, service-fix]
2:ESP_w002_espFaultLamp
3:none
ESP_w003_tcDisabledByFault (Traction control disabled/Drive with caution)
2:ESP_w003_tcDisabledByFault
3:none
EAS_w003_EAS_extremeLowLevel (hidden)
2:EAS_w003_EAS_extremeLowLevel
3:none
MCU_w007_MapsMissing (Navigation unavailable/Navigation maps are not loaded)
audience:[customer]
2:Premium navigation maps are not installed
3:none
CHGS_w108_cpCoverOpen (hidden)
2:CHGS_w108_cpCoverOpen
3:CHGS_a108_cpCoverClosed=--
CHGS_a108_coverTimer=--
bms_values
3.246 3.271 3.318 3.381 3.245 3.265
3.217 3.238 3.220 3.242 3.210 3.236
3.207 3.230 3.212 3.238 3.218 3.232
3.242 3.244 3.239 3.244 3.233 3.236
3.276 3.275 3.277 3.275 3.273 3.270
3.247 3.247 3.241 3.241 3.246 3.251
3.274 3.269 3.270 3.266 3.270 3.264
3.224 3.223 3.206 3.241 3.215 3.235
3.264 3.255 3.263 3.261 3.258 3.263
3.259 3.276 3.253 3.277 3.256 3.260
3.210 3.240 3.222 3.243 3.203 3.244
3.189 3.245 3.188 3.239 3.188 3.227
3.120 3.221 3.105 3.222 3.113 3.212
3.263 3.287 3.273 3.286 3.271 3.288
3.246 3.266 3.233 3.265 3.244 3.257
3.241 3.243 3.244 3.242 3.226 3.239
