Vendor ▀▄ eas | Dinan Suspension Components now available for Tesla Model Y!
tom @ eas
Global Vendor
Oct 11, 2021
1,274
843
Anaheim, CA
Listings
Founded in 1979, Dinan is well established as North America’s premiere BMW tuner. Dinan develops, manufactures, and markets a comprehensive line of high-performance products and systems, distributed through a nationwide network of Authorized Dinan Performance Centers that includes select BMW Dealerships and Independent BMW Service/High-Performance facilities. Recently, Dinan has further expanded its offerings to include other European marques such as MINI and Mercedes Benz.
Dinan’s industry-leading warranty program, quality products, and solid engineering have helped to make Dinan an almost household word among BMW driving enthusiasts. Road tests conducted by major automotive enthusiast publications over the last 30 years place Dinan enhanced BMWs on a performance level with some of the most exotic sports cars in the world. At the same time, Dinan enhanced BMWs are widely renowned for being civilized and reliable, providing a high-performance BMW-like driving experience without equal. Dinan’s comprehensive warranty program, introduced in 1996 with the cooperation of BMW of North America, provides BMW owners with matching coverage to that offered by BMW’s new car warranty, ensuring that Dinan performance enhancements and the BMW they have been installed in are covered for up to 4 years or 50,000 miles. BMW automobiles can now be performance-tuned without the associated concern of negatively affecting the new car warranty coverage, making the idea of enhanced driving fun and excitement appealing to a rapidly growing number of BMW drivers, and now adding Tesla to the lineup.
Dinan - Performance Lowing Springs - Tesla Model Y​
Suspension systems that not only transform the stance of the vehicle but also maintain ride quality and improve upon handling are what Dinan suspensions are known for. This is accomplished by pairing springs sets with bump stops spring perches or both to maintain suspension travel resulting in a smooth ride while also improving mechanical grip and handling. This is what makes Dinan suspension systems unique. While we are able to sell each component separately, it is highly recommended that both the spring sets and the supplemental ride quality and handling kits are used in tandem in order to maintain the Dinan quality standards our customers are used to. Experience the Dinan difference with this combination and enjoy the ride it provides.
Dinan's Performance Spring set for the Model Y provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the car for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot-peened for stress relief to last the life of the car. The increase in stiffness will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip for high-speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle.
Note: Dinan Performance Spring sets should be purchased and installed with the corresponding Dinan Ride Quality and Handling Kit to achieve the advertised ride height performance and ride quality. While not explicitly required, if the matching component is not purchased and installed you will get less than favorable results in the form of poor ride quality and improper handling traits. While we will maintain a full warranty on product defects any claims against the cars improper handling ride quality traits due to not purchasing the corresponding handling kit will not be warranted.
Features
  • Vehicle lowered 0.75" (20mm) in the front and 1.00" (25 mm) in rear
  • 10% increase in spring stiffness in front and rear
  • Substantial reduction in body roll
  • Preset to prevent spring sag
  • Includes (2) front linear rate springs and (2) rear dual rate springs (Ride Quality and Handling Kit sold separately)
Dinan - Supplemental Ride Quality & Handling Kit - Tesla Model Y​
To fully enjoy Dinan performance spring sets we highly recommend pairing them up with our supplemental ride quality and handling kits. This additional kit includes tuned, progressive rate bump stops that maximize suspension travel on the lowered car for improved handling capabilities and ride quality when compared to just a spring set. By allowing for full compression travel within the spring the possibility of a sudden "bottoming out" is negated, a common unwanted side effect when lowering a vehicle. Bump stops also have the added benefit of optimizing the spring rate, rewarding those that use them with added mechanical grip and cornering power. Simply put, the Dinan supplemental ride quality and handling kits amplify performance and comfort when paired with performance spring sets.
Features
  • Includes 4 bumpstops
  • Bumpstops are made from OE quality material for progressive characteristics
  • Bumpstops are carefully tuned for use with Dinan springs
Rekudo - Alcantara Steering Wheel - Tesla Model 3/Model Y​
The REKUDO steering wheel is beautiful, functional, and easy to install. Choose from carbon fiber with leather grips, or Alcantara wrapped steering wheels.
The motorsport inspired design features deep pocketed palm and thumb grooves on the sides to give you a confidence-inspiring and comfortable grip for your hands. The cross stitched silver threading gives the leather or Alcantara section an extra elegant touch that is only found on high end performance steering wheels. The flat bottom gives you extra room for your legs, and the centerline stripe on RK950-01 makes is easy to find center in street and performance driving applications.
Simply put, we've made personalizing your steering wheel easy. This is our own design. We don't modify or wrap your existing wheel. We ship you a new wheel and you swap over your factory controls and airbag. There's no downtime without your car to ship out and modify your existing wheel, and there are no core fees. Simply swap, install, and enjoy!
Features
  • Direct Replacement in Tesla Model 3 or Model Y with No Core or Downtime Required
  • Choose From Genuine Carbon Fiber with Leather Grips, or Alcantara Wrapped Design
  • Flat Bottom Design with Ergonomically Shaped Finger, Palm & Thumb Grooves - for Driver Comfort
  • Carbon Fiber- Sporty Motorsport Appearance and a Great Look
  • Centerline Stripe - Makes it Easy to Find Center When Driving
  • Silver Colored Stitching - for a Premium Appearance
  • Easy to Install - Factory Controls & Airbag are Reused w/ the New Steering Wheel
  • Steering Wheel is Non-Heated and Fits all models up to 2022 with the Standard Non-Heated Steering Wheel
Lowering Springs and Supplemental Ride Quality & Handling Kits are in stock now, more items arriving soon.
Reactions: hyp36rmax
Rekudo - Carbon Fiber Steering Wheel w/ Leather Grips - Tesla Model 3/Model Y​
Dinan - Valve Stem Caps - Tesla​
I got the dinan kit installed today. Really like the look. I'll drive more over the weekend and share the ride feel.
@tom @ eas does dinan spring and bumpstop kit come with dust covers? I found oem dust covers in my trunk when I asked why they weren't installed and he said dinan kits came with it? Is this true?
If you got the Dinan Supplemental Ride Quality & Handling Kit (bumpstops) along with the springs, this take place of the Tesla covers.
Post pics of the new stance when you have a chance!
Enjoy 😉
I have about 2.5 finger gap at the front and 3 finger gap at the rear.
Driving feels, pro is it feels firmer and less bouncier than stock. It feels great especially on a highway, as it feels more planted.
Con is on bad road you will feel the road more. I've never driven performance so I won't know how it feels compared to MYP but I expect it to feel similar as height isn't too different.
All in all I'd recommend it for anyone who mainly drives on highway or live in an area where roads are good.
Cheers!
View attachment 933954View attachment 933955View attachment 933956View attachment 933957View attachment 933958View attachment 933959View attachment 933960
This Alcantra steering wheel is FRESH!
Reactions: tom @ eas
