12.3.6 is described as a bug fix release, it's clearly more because it's noticeably worse than the previous releases. I drove to Vermont yesterday and had the following problems,
The big one, it crashed. I've never seen this happen before but yesterday FSD crashed. It flashed a Major System Failure message, the visualization screen went mostly blank and FSD disengaged. I had to take over and drive while it rebooted which took a couple of minutes. This happened only once.
It's making lot's of unnecessary lane changes, it even did it when there was no traffic on the road. There is a minimize lane change switch but it's not sticky it's for the current drive only. I've haven't experienced this on any earlier rev.
It's gotten worse on exits. It's missing the lane changes to get over for the exit. It's weaving a little on exits. FSD was doing a lot better on exits than before but there has been a significant regression in 12.3.6.
It's having a harder time picking a lane, heads towards one then changes it's mind and picks a different one.
Still can't handle construction. There was a place on the highway where it narrowed down to one lane, FSD made no attempt to merge over to the good lane, it was heading straight for the traffic cones. FSD has never worked for construction, this isn't new to 12.3.6
Ignores speed limit signs that are in yellow or red, it's fine with the standard white signs but it ignores the colored ones that are placed on curves and for construction. Not a 12.4.6 problem, it's never been able to read colored speed limit signs.
