WileyTheMan
Peanut Gallery Member
I would say either method puts stress on the car's charging system, quick high voltage or slow charging at low(er) voltage, so you might as well make it more convenient.
I charged my TM3 for the first year of ownership exclusively with a 120v/15a circuit (circuit is about 12 years old so not old construction, and charged consistently at 111v/12a) before finally getting a 240v/60a circuit installed with a Tesla WC. Here are my nutshell experiences:
Convenience was compromised with 120v charging. I knew that if I had to use the car for anything other than my daily commute, I was charging at a net loss overnight (I couldn't make up the energy used from an overnight charge). This meant more careful planning and was frankly a pain to deal with. There were times I had to leave the car plugged in the whole weekend, and could only use the car if I had no other choice.
It eventually fried my 120v plug. To be clear: I was forced to use a heavy gauge extension cord in order to charge and I know it's not recommended, but the nearest plug was just too far away. I would have to have hired an electrician to locate a plug closer, and at the time I could not afford deal with potential revised building requirements that might be required in order to get my permit for the work. And if I was going that route, I might as well wait to install something faster. Anyway, the cord would get warm while charging and eventually burned out the plug itself (not the circuit) within nine months. I didn't learn until later that the mobile charger has a thermal safety feature that prevents that from happening, but it won't work on an extension cord, apparently.
I am incredibly happy with the 240v circuit I had installed, and do not regret it at all. It addresses all my negative experiences with 120v charging. I can finally relegate the mobile charger back to what it was made for: Backup charging when you have no other sources.
