We were discussing this ourselves. Decided to go the garage floor route since this would allow us to add a third at a later date by stacking next to each other otherwise you’d need even more wall space with the appropriate clearance.
The side of the garage we plan for installation of equipment is “down slope” from our water heater. We asked if there was a water heater leak at some point if that location would pose a problem for the units but were assured it would not.
We have 2 powerwalls being installed in a couple of weeks in the garage. Should we mount them on the garage wall or floor?
Here is a picture of my floor mounted powerwalls.We have 2 powerwalls being installed in a couple of weeks in the garage. Should we mount them on the garage wall or floor?
You should put some small feet underneath in case you plan to resurface or paint the floor.Here is a picture of my floor mounted powerwalls.View attachment 513743
It has feet. Hard to see.You should put some small feet underneath in case you plan to resurface or paint the floor.
Here is a picture of the space we are working with and the projected space required for 2 PWs. The floor install is closest to garage door. For scale, the 2 wall mounted options protrude about 7" off the wall. But they are not pushed 2" away from the wall by the cement curb like the floor mounted option. The car is our Model 3 and shown in it's normal parking spot.
We originally were planning on mounting on the wall for visibility and cool factor. But now are wondering about the potential interference with the passenger side door of the car and amount of wall space used in the (unlikely?) event we decide we want to add a 3rd PW.
It is planned that the other boxes in the solar setup would be mounted on the outside of this wall about from the vertical blue tape toward the camera.
To make things more complex, we are planing on having this wall cleaned up and painted soon. But, the contractor will NOT be able to get out before the PWs are installed on March 3rd or so. We are hoping they can work around the PWs.
They come on the bottom of the powerwall.Do the feet come with the PW or is this something you added?
We were able to get our 4 PowerWalls mounted in two stacks inside our garage with no exposed conduit inside the garage. There is conduit on the outside wall from the PowerWalls running to the generation panel.
Main electric service panel and meter.Nice. Just curious, what is the housed in the enclosure by the door?
Our installers were able to integrate the generation/Gateway panels in with the panel and runway that were already there for the house power. It was a tight fit, but they got everything to fit into a pretty small footprint outside, with only one conduit going to the side for the PowerWall connections and another one going straight up into the attic eve (no exposed conduit on the roof).
View attachment 514241 View attachment 514244
The purist in me just wants to grab a master electrician and have him simplify that jumble of boxes.
I have something similar, and it drives me bonkers.
