Having PWs 2 & 3 installed tomorrow. PW 1 is on a wood-frame wall in a walk-out basement utility closet under the stairs. I could mount 2 & 3 so all 3 are on a wood-frame wall in a row with maybe one foot separation between each.
I can also have them drop PW 1 to the concrete floor and sandwich all 3. Probably a tossup from a useful storage space standpoint.
The only functional concern I can think of is if the basement flooded. Highly unlikely as my sump pump is rarely called upon. Even if the sump pump failed, I have 3 floor drains between sump & PWs with 2 of those drains close to the PWs. If the drains failed, water would likely just run out under the wood-framed back wall.
Any other factors to consider or is it just down to personal preference? Thanks.
