I removed the on-board charger to replace the two 50A fuses. After reassembly, I am getting a "Cntctr State" error message. I suspect a charging contactor switch failed as well. Or it could be a contact switch that did not get reassembled correctly so the power is cut by the system. Does anyone have any suggestions about what to look for. Here is what I believe to be the relevant diagnostic information.
Contactor Cut OFF Relay Connect Request ON
Contactor Cut OFF Relay Status ON
Cause of READY ON Failure Shift Oper
Cause of Forced Charge Cancel Cntctr State
Thank you
Thank you
