Yours is change, isn’t? Mine looks like this and it’s not adjustable. Also changed to motorised version. To the OP, if you have no functions on the door then there might be malfunction on it. The door is separate unit, functioning together with the charge port. It usually should generate corresponding error too. If you know that you have manual door then there is no worries to pry it open. If you have any resistance on the door (motorised version) then you might damage that hinge part.
