2016 MS: Would this configuration for rim/tires work?
I have an old set of base rims OEM, but have a friend who might be able to help me out with Continental ProContact Rx (255/45/R19) off his MY. I would be putting these on my 2016 MS S90 ... Do the rims fit in the slightly larger tire 255 vs the typical 245 for the MS? Thanks everyone, I'm very new to this!!
Spacers means that you can extend the rim+wheel placement outwards and this 5mm would give possible solution for the wheel inner edge to not be in contact with wheel liner if turning needed. Theoretical fitment means that the rim would be OK but you are increasing the tire width and as of that wheel outer wall hight. This is relevant for the car/model you are trying to put them on.
