I recently have a test drive and was told newer custom order Model X has no longer has dual charger built in the car. So this means that there is no point to buy a HPWC at home any longer. Can any one verify this?
Your onboard charger converts AC to DC power. Superchargers and other fast chargers provide DC directly, bypassing onboard chargers. So no, you'll get the full charging rate at superchargers no matter what you have as an onboard charger.Thanks for the clarification. I meant the on board charger only 48A now. What about when using the public Super charger? Am I only going to get 48A max only?
You have a lot to learn grasshopperI thought the Tesla public super charger are AC charger only since it use the same connector charger for the HPWC. But I could be wrong.
The Nissan Leaf use separate connector for direct DC current charger than home charger plug used.
Both. L1 and L2 EVSEs feed standard AC to the charge port (either 120V or 240V for residential and 208V for industrial) and the car sends it to its onboard charger, which feeds DC to the battery. When a Tesla Supercharger is connected, the car's high voltage junction box switches over to feed the DC from the Supercharger straight into the battery.
The port is J1772 compatible when AC charging (standard documents are available online, a physical adapter is provided with each Tesla--the adapter doesn't have any smarts) & is Tesla proprietary when DC charging.
Great Tesla car has one charger port only can do both AC and DC current. Better than Leaf.
I plan to run 80A breaker to HPWC charger which is what recommended. With the new model X car it only has 48 Amp charger on board. If I need a quick charge between couple hours,I would not be able to charge higher than 48 Amp? So there is not point to run bigger wires rated for 80A breaker since the car can only handle 48A for the HPWC. I am thinking wires rated 60 Amp breaker should be enough. Let me know if this is correct.
a) You need to ask yourself if you will ever have more than 1 electric car in the area that you subpanel will be. We have a 60 amp subpanel in our garage but we are charging two electric cars now at night so I have to turn them both down (lower amps).Great Tesla car has one charger port only can do both AC and DC current. Better than Leaf.
Thank you for posting this, it needs to be said more.a) You need to ask yourself if you will ever have more than 1 electric car in the area that you subpanel will be. We have a 60 amp subpanel in our garage but we are charging two electric cars now at night so I have to turn them both down (lower amps).
b) You need to ask yourself if you will ever get a different car in the future that can charge faster and need more amps. What will 'tomorrows' cars be able to charge at.
Wire really isn't that expensive and a little overkill now could save a lot later.
There’s no such thing. They have come with 48A and 72A chargers.I am think should I order an used Model X that has 60Amp on board charger.
You should explain your Mon-Fri commutes/activities/scenario and your Sat-Sun activities/scenario. ie. miles travel, time at home, weekend time at home vs activities.I am disappointed that Tesla do not offer 64Amp charger on board as optional package.
I plan to order new Tesla Model X by June 30th of this year to get the Federal tax credit. I am think should I order an used Model X that has 60Amp on board charger.
Except that's not what the ratings are for. AWG 4 is rated for 60Amp PEAK, but only 48Amp CONTINUOUS. AWG 6 is rated for less than that, so using it would not be considered safe per code since the charger would draw 48Amp CONTINUOUS.In theory you should use AWG 4, in reality that circuit will never see 60A so AWG 6 is fine
