Yes, that must be the part number of my 2.0 Center Console. I never actually looked at the label to verify the part number.
Tesla now lists that part number, but also another
variant, which is
1755503-70-C. My guess is this is the latest
without the data cable. So, if you order the earlier part, it should come with the data cable bound by felt tape into the console's wiring harness.
The installation is much easier than TesBros video, as he makes several mistakes before getting it installed properly. The install is quite easy and minimal time to install, however the prep work can take significantly more time. The side carpet panels are not easy to remove without a proper pry tool (I made mine from a metal trim tool kit I bought at Harbor Freight Tools). The Tesla Service Manual recommends two-person removal/install, however I did this without a helper.
Swapping out the Security Controller requires partially dismantling of both consoles and may not be easy unless you have experience doing that, The copper colored metal spring clips, on the black side trim pieces, need some gentle persuasion with a pry tool ( I used a putty knife wrapped in masking tape). Once you partially release these spring clips, you need to hook the clip with the pry tool to do the final pulling. Otherwise, you risk pulling the clips from the side trim which can damage the plastic where the clips attach to the side trim.
I can't recommend the more expensive aftermarket USB-C hubs (like TPARTS) because they
may not be built with semiconductors that meet the more stringent automotive semiconductor fabrication standards. Thus might be more likely to
fail in a harsh automotive environment, before the car approaches end-of-life.
Here's a photo of the
side carpet panel pry tool I made from HFT trim tool kit.. Slips under the bottom of the carpet panel, then pull with handle, working on both sides, from the rear bottom, then releasing clips and moving toward the front to release remaining clips.
