21" Squared on Model Y LR
What is the best squared setup on 21" for mylr? I see myp is 10.5 rear and 9.5 front. Only want a squared setup due to longer tire life with rotations.
  1. I heard if you put 21/10.5 front there is rubbing.
  2. Is the suspension on a mylr different that you can't put 21's" on a LR?
  3. I have 20" but want the look of 21" is that possible and are there negative effects? loss of warranty? Range?
  4. Can you do 21" squared 9.5? Is 9.5 to small for the rear? Like weight issues? Bad looks? Can you even tell?
  5. What about tires, is there a recommended 21" 9.5 squared setup with identical tires? If so does anyone know the tire sizes?
1. depends on the offset of the rim, but if it sticks too far out it’ll rub on the fender when fully loaded.
2. MYP is a little lower (about half an inch) than MYLR, that’s all.
3. mostly range and comfort are negatively affected
4. will probably work fine, again depending on the offset of the rim, will look a bit more tucked at the back then OEM 21s
5. sorry, got no recommendations here
