22 MX Plaid Wind Question….need help
I need help from the experts on this forum. I have a mild wind noise from the drivers window and have isolated it to the rubber attachment between the small and main window. Please see attached pictures. When I place a small towel and hold it there the noise is gone. How can this be fixed and is it a major thing to fix? If it’s involved I’d rather live with it then let Tesla mess around with my car….I have too much OCD and their level of service leaves a lot to be desired. Thanks in advance!
HI... i had the exact same problem... a small towel would eliminate the noise. tesla couldn't fix it after a couple tries.. they even changed out the "delta window" which was the small triangle. Instead of bringing the car back a third time, I started trial and error and found out the noise was between the main seal on the car and the triangle..... i bought a weather strip from amazon...
i put this on seal on the car frame where that triangle window touches and the sound was gone...... previously i had tried putting it on the delta window along the edge, but that wouldn't fix it.... it should go on top of the black seal attached to the car
