6-50 plug only charging at 120v
Sporty
572
613
Seattle
I have a 6-50 plug with a TMC plugged into it. The car is only charging at 120v. I think it used to charge at 220 but I’m not positive. What are the likely causes?
I don’t know that it matters but when the car is plugged it sounds like the TMC engages and then disengages. Eg sound like a relay flips twice. I’ve tried another tmc and m3 with the same result… so I suspect the plug or wiring.
Perhaps you should take a look at the outlet wiring and make sure its not damaged / burnt etc. If thats not something you are capable of doing, then you should hire an electrician to come out and look at it.
I certainly wouldnt charge on that circuit until I figured out what was wrong.
