I'm not a Tesla owner, I did some research on this, and I saw that Tesla browser won't be able to access any internal IP's when connected to the Wifi, however, I wasn't able to find out if that also refers to the gateway, example if you connect to your home's Wifi can you access the routers admin page, using the IP, as gateway should work slightly different.
I'm asking this because I'm the developer of the Headunit Reloaded app ( https://play.google.com/store/apps/details?id=gb.xxy.hr ) and I'm thinking of a pretty complicated way to make Android Auto work over the built in browser, I have no clue how performance will work out as, no video can be actually shown on the units, so I will need to find a way to convert a h264 video stream to an image sequence and show them in a browser hopefully at a reasonable refresh rate for it to be usable, but if the browser cannot connect to the gateway's ip address either, then it's pointless to even start the development on this project.
You're feedback/input is appreciated.
Thank you.
Thank you.
