I'm considering getting the Forgestar F14's for my Plaid MX in this color combo (my MX also has been wrapped with XPel Stealth)
As much as I like the look of the 22" wheels however, I don't like the discomfort and vibrations so I'm looking at the 20" versions. After a query to Forgestar, it seems the options are: 9J, 9.5J, 10.5J. The stock Cyberstreams I currently have on there are a 9J / 10J configuration, so I would have to go for a 9J/10.5J or a 9.5J/10.5J combo.
Now the stock 9J / 10J configuration uses 265/45/20 and 275/45/20 tires. How do I adjust for the extra .5" width? My semi-mathematical brain is looking at the problem like this:
265mm = 10.4331" (9J front)
275mm = 10.8268" (10J rear)
Going up 1" in rim width means going up 0.3937" in tire width which is basically 10mm. So going up 1/2" means sizing up by 5mm.
So question # 1: does this mean the "correct" tire sizes for 9J/10.5J would be 265/45/20 and 280/45/20, and for the 9.5J/10.5J it would be 270/45/20 and 280/45/20?
And question #2: Any thoughts on 9J vs 9.5J on the front? I assume 9.5J would give more traction but also less range due to friction.
