I've owned a Model 3 Perf. in the past and purchasing another one, soon. It'll be a 2021/2022.
My biggest gripe about the car was it not having great chassis dynamics. Weight transfer was slow, rolled a lot in turns, etc.
I'm wondering if the OEM dampers play nicely with aftermarket springs?
Ideally, I'd like springs that lower the center of gravity slightly, and perhaps progressive (so I enjoy OEM-ish comfort cruising and a higher spring rate under load).
Emphasis on working with the OEM dampers valving and range, as I don't want to invest in aftermarket dampers also.
Thank you!!
Thank you!!
