@kev1n is this passthrough to OEM sub when connected or kill the OEM sub when plugged in?
OEM sub is still working -- i have no clue what happened, but i'll see if i can find a way to test my equipment this weekend. Thanks for the quick response!mine is working, im on the latest FSD update. i dont see why it would stop from an update though, youre just pulling signal from these taps. i would check your equipment & is the oem sub working?
they are for signal to your amp. normally without this harness, you would have to tap/splice into the OEM wires. this harness will clean up the install and you can revert back without leaving any trace behind. send me a dm if you want to buy, i see you are also local. thanks
if your oem sub is working then it has to be your aftermarket equipmentOEM sub is still working -- i have no clue what happened, but i'll see if i can find a way to test my equipment this weekend. Thanks for the quick response!
i do not know unfortunately as it will depend on many factors. whether they use the same connectors? how much of the oem harness is still intact if you dont have prem audio?Anyone know if this will work on a 2019 SR+? Has no factory amplifier? Just bought my sister this car and am trying to get everything installed before I take it to her. I ordered the “Hansshow M3 SR+ 17-20 DIY speaker activation upgrade wire harness kit” which turns on the six upper speakers, so that should make it sound quite a bit better. I have an OEM subwoofer. I took out a totaled car and I was going to use the Alpine Ford channel bridged into two channels, one for each voice coil. which turns on the six upper speakers, so that should make it sound quite a bit better. I have an OEM subwoofer. I took out a totaled car and I was going to use the Alpine Ford channel bridged into two channels, one for each voice, squirrel coil coil but since this car has no amplifier. Since this car has no amplifier, would I still be able to tap using this harness? ThanksView attachment 892725
Hi Kevin, I am interested in purchasing a harness from you. I have a 2021 Model Y Performance. Will your harness work?For Model 3/Model Y. this plugs into your OEM subwoofer harness
This harness will allow you to plug into the subwoofer wires to draw signal without having to tap or mess with the existing oem wires.
this is for if you are installing aftermarket subwoofers into your car
plugs right in for a clean install!
i have 8 of them available, $60 + shipping
yes it should work. ive had Model Y owners buy it as wellHi Kevin, I am interested in purchasing a harness from you. I have a 2021 Model Y Performance. Will your harness work?
Do you have an Instagram? Would be easier to communicate that way.
Thanks!
Hi,For Model 3/Model Y. this plugs into your OEM subwoofer harness
Hi, I’m interested. Do you ship to Aus? And are you able to dm me with install instructions so I can see where this would install? Thanks, great idea!For Model 3/Model Y. this plugs into your OEM subwoofer harness
sorry i do not ship to AusHi, I’m interested. Do you ship to Aus? And are you able to dm me with install instructions so I can see where this would install? Thanks, great idea!
if you dont have the oem sub to begin with, this harness cant be used in your carHi,
I'm interested but also need instructions. Where exactly does this connect to? I have a 2022 Model 3 SR+. I purchased an OEM Subwoofer with the amp. Doesn't the amp have 3 places to connect wires to?
Hi Kevin, can you provide a diagram for this?
