"Alcantera" dash wrap
pdk42
1,743
1,916
Leamington
So I eventually got around to wrapping the wood dash trim in suede/alcantera. Total cost £17 and about a half hour of fitting.
This is what I used. Enough for two dash wraps:
That looks fantastic!
How did you fit it? Contact adhesive?
No, the wrap is self adhesive. Pretty easy to fit since the dash is a simple shape. You need a spludger tool (or a credit card) to flatten out the wrap and force it into the lip where the wood meets the plastic and then a sharp knife to cut it at that line. The only slightly tricky bit is doing the outside corner on the left and right at the back. But a little wedge cut will sort that and because the material is fluffy, any slight error here won’t be visible.
Reactions: Mgd1
How close colour is it to the fabric on the door panels ? As I would be interested on a 22 model 3 with wood door trims too
It's a tiny bit darker, but not a big deal. It'll probably fade in time anyhow.
Regarding the door trims in later models - it seems that the wood inserts are not too hard to remove and wrap. Do a search on YT - there are some vids there showing it.
That looks good pdk42. Another Bimmerpost refuge here!
What’s that dashboard that you have, looks interesting?
It's the "Top Fit" display. I did a post about it here:
Reactions: MashinBenzin
