Rear view camera? You mean the in cabin camera?
I did this a little while ago. There’s nothing really to add. I’ll just go over the steps I remember, which should be the same as the video.
Soft (non-marring) pry tool to pop the plastic on the back of the mirror “arm.” It slides down, once you pop the clips/hooks near the top.
Torx tool to detach the actual mirror, unplug wires accordingly.
Use a hook type soft pry tool to pop the large plastic away from the windshield. Popping the plastic parts were pretty hard for me, with this one being the worst.
It was so bad, I had trouble when putting it back on.
Anyway, at this point, I think I left the plastic hanging by the wires. It should be fine, as long as you don’t tug on it.
After cleaning, it’s pretty much just the reverse to put things back.
Getting everything to pop back is annoying as hell, but nothing you can really do, other than to take your time and make sure everything is lined up.
There was a small hook plastic wire that keeps the smaller plastic vaguely attached. But seeing it wasn’t particularly useful, I mangled it to bits to “remove” it. Should’ve just gotten a cutter or something, but oh well.
