Any SR Owners Wired Up Map Pocket Lights?
Discussion in 'Model 3: Interior & Exterior' started by AdamMacDon, Feb 18, 2020.
  1. todd2fst4u
    todd2fst4u Member
    Menlo Park
    This is from the owners manual about the behavior of the 12v center console socket (what the light blue wire feeds). 08209E5A-CF38-4008-A421-E6E49635DB01.jpeg
  2. AdamMacDon
    AdamMacDon Member
    Victoria BC
    Yeah, any time the car is not "sleeping" it will be powered, but considering the lights draw a minuscule amount of power (next to something like sentry or charging), I'm not too worried about it. There is another wire you can use that is apparently switched to a driver being in the seat and the "ignition" on, but it's on the passenger side and I don't want to have to run wire there.
  3. todd2fst4u
    todd2fst4u Member
    Menlo Park
    I’m not concerned about the power draw but I don’t want to have the interior lights stay on when I’m not in the car. Thanks for posting that video, I hadn’t seen that one before. I’ll look into that wire.
  4. AdamMacDon
    AdamMacDon Member
    Victoria BC
    Yeah I mean ideally I'd turn them off too, but I'm not too worried about either the light/heat they produce or the power draw. I'll probably just rewire it to the console 12v power when I do my sound system upgrade. Crazy how one has to consider software patches when doing hardware mods to their car now, haha.
    Let me know if you end up finding that one wire, the video wasn't super helpful for picking the right red wire in a sea of red wires... I may have to consult my wiring diagrams.
  5. todd2fst4u
    todd2fst4u Member
    Menlo Park
    I was able to wire up the footwell lights as well as the front and rear door pocket lights. I used a relay triggered from the center console storage led so the lights come on when you open the door and turn off when the doors are closed and the screen powers down. I was able to access the orange wire feeding the rear door pocket leds in the B-pillar.
    This picture is from the drivers side. Only one orange wire is in this bunch so it’s easy to find. On the passengers side, there are 2 similar orange wires. I tested both to find the correct one.
  6. AdamMacDon
    AdamMacDon Member
    Victoria BC
    Thanks for the info, when I do my premium sound system upgrade I'm for sure gonna wire up the rear door lights too. Adding a relay in might be an idea as well, I know for sure I want to add a physical switch under the dash so I can force off the lights in camp mode, they are kind of annoying when trying to sleep and it's pitch black outside.
  7. B.K.
    B.K. Member
    Bay Area, CA
    Anyone have any luck finding and tapping into the puddle or overhead lights? Not too interested in the ambient light solution.
  8. Mr X
    Mr X Future Martian
    Simi Valley, CA
  9. B.K.
    B.K. Member
    Bay Area, CA
    Ok, for my SR+, after finding the wiring diagram, it looks like the puddle lights are controlled at the door latch switch, therefore the primary area to tap into the line is basically right at the puddle light. Tapping into the puddle light prior to door wiring harness, you can only access the power but not the ground switched from the latch, which would result in power on even if the door is closed and if grounded elsewhere. I also don’t know the behavior of the puddle power while it is in drive mode for example. I am thinking about stringing a wire to the puddle lights, through the door, and hooking up the foot well lights, including adding two in the rear. I’m okay with only having the footwell lights on when the door is open, since nobody has found a way for it behave like stock, especially dimmed while driving. I can also attempt to enable the map light using the same line. Will 3 lights on the same line cause issues? Someone talk me out of it.
  10. B.K.
    B.K. Member
    Bay Area, CA
    Finished powering the front passenger footwell light by tapping into the door puddle light. What a pain just to get some semi functioning lights. 3 more to go. I didn’t have pocket lights and it wasn’t obvious where the cut wires were (I didn’t open any of the wrapped tape).
  11. B.K.
    B.K. Member
    Bay Area, CA
    Was able to finish tapping into the door puddle lights (so they only turn on when the door is open). Was able to string the line without taking the front windows out. You have to take out the rear windows. It took me a couple of days taking it slow. I installed slightly brighter lights from Oznium and used a couple of the stock lights to brighten up the trunk.
