Anybody installed these "widebody" fender trim?
These help cover my +25 offset wheels pretty nicely. Typical plastic material and fitment about 8/10. Very tiny gaps between the fender and flare that whistle on highway which probably can be close up with heat gun and pressure. Satisfied overall 👍
Hmm. There's already so much wind noise on the Model Y, I'd be hesitant to extend the fender wheel arch out.
My opinion, of course. FYI: 45k miles, front OEM mudflaps, rear door PPF, and zero issues with road debris striking the sides of the car.
YMMV!
I’ve driven all Tesla models over the past few weeks, the y is less noisy than the x and the 3.
The s is about as noisy as my y.
I have the 23 GigaShanghai model Y, but I don't think either of these work well for that model? The Tesmanian ones have cutouts for the non-existent sensors, and above that I'm getting this body kit:
I don't think that will fit on :(
Is it expensive to colour match those trims if they would fit??? (Blue)
The build quality on these aren't great from the ebay seller I got them from. Just 1 out of 4 fender flares fit perfectly, but I still had to trim the black gasket off all the white clips.
Reactions: Du30
Front: 22x9.5 +28 265/35/22
Rear: 22x10.5 +36 285/35/22
Hey sorry to bring up this old thread (couldn’t figure out how to PM) but I had a question about your offset. I’m about to order some 22’s for my MYP and read through your posts. Are you running any camber at this offset? I saw earlier you were running less offset compared to these numbers. Just double checking you didn’t need to do anything else to prevent rubbing. Thanks!
