cmarshack
That's me. It does work. If you get tired of being cold in canada, come down to Texas and I'll show you!
There are no different alignment requirements for 19s vs 21s vs 22s. It just comes down to making sure your offset and tire size isn't so big that you run out of room in the fender well. But if you use my same tire sizes, the OD of my 22" wheels/tires is the same as the factory 21's, and the offset is about the same as well - just pop your 21's off and pop your 22's on.
I've found that many S's with the factory 21's rub, and it's because of the caster setting more than anything else. If you have rubbing with 21s or 22s within the factory tire OD, have an alignment shop adjust your caster and you'll never have a problem again.
Caster affects the position of the front wheel in the wheel well. It's adjusted on the front lower control arm, so you have a decent degree of room to eliminate rub in 99% of situations. My current Caster setting is +4.5 degrees on both sides, right within Tesla spec.
The only time my car rubs is when I'm taking a steep incline at an angle - and that's just because lowering means less suspension flex. But I have air suspension, so I just pop it back up to "very high" when making those entrances, and have no problems.
There are still a decent amount of tire options for 22's - I usually use Pirelli P-Zero Nero GT, but I'm trying ut Lexani's right now as a low cost option. The Vossens are a hybrid-forged wheel, so they're SUPER durable. Way more than the factory 21's. I've gone over holes that would crack a Tesla 21 and come across with no issues.
I have run 22" on 2 different lowered Model S's, and Aggmeister is spot on here. Nothing more to add.
With respect to tire wear, the older S's have know issues with bushing wear in the upper control arm that leads to excessive negative camber in the rear that cannot be adjusted for. This, with low profile tires causes the tires to wear unevenly and fail very fast.
See below how much tread is left here and the tire is toast. I added camber bushings after that photo to fix the issue.
