I just had the Homelink Automatic Garage Door Opener hardware installed today and spent more than 3 hours trying to get it to function properly. I programmed, then deleted and re-programmed about two more times, then rebooted and again programmed and re-programmed and again re-booted and finally got to open and close the door via the manual use of the icon on the display.
Once it auto opened on approach and once auto closed on departure but had to stop and unfold the mirrors.
Any help of getting it to work properly welcome.
Is the function fed by blue tooth, by wifi, or by cellular signal. I did notice that I had a weak wifi broad signal with only the dot at the bottom---Could this be the problem?
