Since I haven't seen a basic walkthru I'll just have this here for reference for those of you who are curious what steps are needed to get this done.
2021 Model Y Performance build date of 9/21
Part# 1537264-00-B
Price: $152 after tax from Tesla San Francisco
Tools: flat head screwdriver, 10mm socket with 6 inch extention
1. Pry off the tail gate plastic protector...note i have metal pieces but its a pull straight up from the left side, give it a good pull and it will come lose very easily
2. remove plastic round clip with flat head screw driver...its the one at the top of the pic
3. remove this plastic piece...pull straight up , comes out easily
4. remove plastic clip the one in the middle and remove the entire piece for the plastic pocket
5. pry the panel with your hands pull slowly down the length of the panel...
6. unplug the rear cigarette 12v power clip
7. The ecu is behind the black plastic bracket
8. remove the 10mm bolt and slide the ecu to the right and it should come out after you unplug three connectors....one of them was a little stuck but work slowly. the car will make some sounds when you start unplugging these clips. Plug in new ecu and re-install.
9. update the software!
10. wooo!
