279 being the most that you can charge is an indication that the max charge level is set to about 90%. That can be changed, but it is not recommended to go higher.
The mileage available is the mileage when you are using EPA driving habits. I wish that they would use actual expectations instead, but it is what it is.
So your question is that you've only driven 80 miles, but that car indicates that 181 miles have been removed from the indicated driving distance.
First, these are never real numbers. The accuracy of the ability to calculate some of these numbers have a lot to be desired. If you are off 10-20%, life isn't bad.
But you are off 100%. So what causes this? Driving fast is the best way that you can drain the battery. From what I've seen, start at about 55 mph, every 5 mph that you go above this can drop your efficiency 10%. This is caused by the increased drag from the air. Want to maximize efficiency, 45mph is where you want to be.
And really fast starts at traffic lights aren't good for range either.
Another use of the battery is the cooling/heating system. A few weeks ago during Drive Electric Week, as I was showing the car, the door kept getting opened and the AC would kick on. Over about a 4 hour period, I lost about 40 miles of range. In addition, when you first start the car, the AC comes on and tries to condition the batteries. This means that for the first few miles, you average kWHr/mile is really high.
Another use of battery and what is called phantom drain, is the power that the car uses when you aren't driving it. The car will generally go to sleep after it locks, things power down and become quiet. But there are times and situations where the car doesn't go to sleep are keeps getting woken up. Some third party software will keep the car awake. And if you are looking at it in the app, that will also keep it awake.
So, it is best to charge every night. And if you do, keep the max charge to at least 90%. 80% seems to be a more common number. With only a 20 mile commute, 120V charging will be a great option for you, it you don't have 220V at home. And charging at home is by far the best way to experience an EV.
Stay off the lead foot, keep that max speed down, turn on EAP and enjoy the drive.
