Looking to improve the performance of my vehicle. I have a stock P3D-. I'm not a fan of the tires. I want to decrease the braking distance and increase the brake pedal feel (it feels dead compared to the accelerator). This has led me first to tires, then look into brake improvements such as pads.
I don't track but would like to maybe get into autocross a few times a year. Due to being a daily driver that will mostly almost completely be kept on the street, I have decided to go with PS4s tires, just have to figure out the sizes and if I should change wheels.
Option 1:
Keep stock aero wheels, add 245/45 PS4 tires.
- Tread width of 8.1 inch (half inch increase vs stock)
- Weight 25 lbs (same as stock)
- Pros: best compatibility, fill wheel gaps with not issues. A little higher but nothing noticeable means lower risk of bottoming out although that's not really an issue. This is the best compromise although I 'm not big on the look of even bigger tire sidewalls.
Option 2:
Keep stock aero wheels, add 245/40 PS4 tires.
- Tread width of 8.4 inch
- Weight 23 lbs
- Pros: 2 lbs lighter tires than OEM or 245/45 and more tread. I'm wondering if this will help slow the wheels more quickly and improve brake responsiveness in addition to compound and width increase
- Drops car about 0.3 inches and adds about 0.3 inches to wheel gap. May go with a slight suspension drop if I go this route if I can find springs that improve street ride. Considering UP mild springs but have seen bad reviews about plastic attachment parts braking and being left with the bill for the damages/terrible customer experiance.
Option 3:
Keep stock aero wheels, add 255/40 PS4 tires.
- Tread width of 8.7 inch
- Weight 25 lbs
- Wider tread gains but no weight gains vs OEM. Negligible decreases in ride height/wheel gap increases (1/10th of an inch). These are getting more expensive though.
- Max load rating is higher at 1709. I wonder if this will make the ride more stiff/harsh or be unnoticeable yet less likely to bend rims and improve cornering.
Option 4:
New wheels with 255 or 265 tires (likely 255's due to weight savings and cost although 265's make my mouth water. 265 may also add to paint wear behind the fenders due to rocks being thrown up I don't get fender flaps or the like)
4a) Titan 7 T-S5
- Forged and likely best durability for bad roads.
- 20 lbs, so a little over a lb in savings vs OEM without aero caps. Not much of an improvement beyond looks and wider tire compatibility.
4b) Yokohama ADVAN RGIII Wheels
- Lightest at 18.5 lbs
- Flow cast so not sure on durability
- My fav look by far! Would likely go this route if it weren't for the next issue
- May require rim modifications as I think MPP had to have a machine shop bore out the lug nut holes. If these aren't direct bolt on that's prob prohibitive as I don't want to risk modifications to wheels.
Also not sure about wheel hubs. May go with MPP light weight 2-piece rotors later on. Not sure how either of the above is compatible with those and/or OEM rotors.
Option 1:
Option 2:
- Weight 23 lbs
Option 3:
- Weight 25 lbs
Option 4:
4a) Titan 7 T-S5
