Thanks for your tips. I need to look into this.I live in sunny California. I have used two effective options. First, yes, the Tesla roof shades do work. I bought both the rear window shade and the smaller one for directly above the driver. I have found the one for the driver alone to be sufficient. Second, I highly recommend that you get the windows tinted using a high-quality ceramic tint. I personally chose Xpel Prime XR Plus and it definitely keeps the cabin much cooler. The AC turns on less often to keep the cabin comfortable. And with ceramic tint, you don't necessarily have to go super dark to get heat rejection. I chose a very light 55% tint, as I want to keep the inside light and bright. Even with that light tint, the ceramic tint still rejects a lot of heat.
Most likely to keep production costs lower. There is an aftermarket product that clips into the M3 glass panels and are able to manually retract, I forget the name of the product but it has decent reviews from what I recall.It seems silly to have a panoramic sunroof that we have to keep covered up all the time. Other cars I've had with pano roofs had nice motorized shades that were very effective at rejecting heat, but also allowed one-button retraction when sunshine/heat wasn't an issue. But with my M3 I have a huge glass roof that I can't even enjoy because of the searing heat.
Why can't Tesla do this?
Many of the new ones might not have them anymore, but my aftermarket shade came with a separate reflective cloth layer.I know this is ghetto, but I actually thought about using a sheet of aluminum foil between my aftermarket shade and the actual glass roof (with the shiny side up, of course). But I worry a little about that that might concentrate heat on the glass and pop it. The shade has some shininess to it, but not much.
Anyone done anything like that?
Roof shades will help a lot with that. It won't prevent the car from getting hot in the long run, but it will reduce the direct heat you feel on your head.Yeah, the one thing I really dislike on my Model 3. The glass roof is getting hot hot hot, it is not just the rays coming inside the car, the glass itself becomes super hot.![]()
I hadn't thought about the mylar blankets. That might just be the ticket!Many of the new ones might not have them anymore, but my aftermarket shade came with a separate reflective cloth layer.
I also have a windshield reflectors from my old car (that I still use) and there is basically a foil layer on both sides (which sandwiches bubble wrap in between).
Doing a search, people seem to say mylar emergency blankets work far more effectively.
I suppose there is some risk of causing an existing crack or chip to spread, but I haven't found people saying they had issues using such reflective shades.
I tried a solar panel also in the rear parcel shelf of the car to keep a battery for my security camera system charged, but it was close to worthless. Too much energy is lost from going through the glass and/or there may be times of shade where the C pillars block it. I tried multiple different types of solar panels, even tried different controllers. In the end I returned everything and just spent the money on extra batteries.I use reflective roll insulation under the glass and then put the shades on to help hold it in place. It looks great and is extremely effective. But, as noted above, heat will always get in. Insulation buys time, that's all. A/C (or at least the fan) will always be needed, but how much is the key.
Reflective Insulation Example (Lowe's)
What I really wish is for the roof to have solar panels (ala Fisker) and use that energy to run the fan to keep the car cooler. I once put a solar panel under the roof of a Model Y. It didn't get much kept a spare battery in the car topped off.
At home, I have a 13x13' pop up canopy that helps keep the sun off on days like this in SoCal (June Gloom burned off early today and yesterday).
Rather than aluminum foil, try an aluminized mylar space blanket (emergency blanket).I know this is ghetto, but I actually thought about using a sheet of aluminum foil between my aftermarket shade and the actual glass roof (with the shiny side up, of course). But I worry a little about that that might concentrate heat on the glass and pop it. The shade has some shininess to it, but not much.
Per my post right above yours, I did use a space blanket, with great success. My roof shade also has a slightly reflective surface, and although they tout it, it didn't do a lot to keep the heat out..Rather than aluminum foil, try an aluminized mylar space blanket (emergency blanket).
I use a roof cover similar to this:
that has a reflective upper cover.
Ours seems to work pretty well, and it keeps the car cooler in summer and warmer in winter.Per my post right above yours, I did use a space blanket, with great success. My roof shade also has a slightly reflective surface, and although they tout it, it didn't do a lot to keep the heat out..
