I came up with this simple program I called BlackvueDaily. Basically it downloads the videos from your blackvue wirelessly without you having to remove the SD car from the recorder. It's a simple .exe program that takes certain parameters. You can download the program from here: Dropbox - BlackvueDaily.exe
There are parameters you can use and one of the parameters that has to be there is the location of where you want the downloads to go preceded by a "-". It automatically uses the IP address of the blackvue recorder when a computer is connected to its SSID, ie http://10.99.77.1. However, one can put in there own IP address of the camcorder as a parameter such as "-192.168.1.22" if you don't have a wireless dongle connecting to the recorder. Only one other parameter will work for now as listed:
-all ---- This will download all the videos from today
-front ---- This will download all the videos from the front camera from today
-rear ----- This will download all the videos from the rear camera from today
-park ----- This will download all the videos while car was parked from today
-event ---- This will download all the videos that records when an "event" occurred
For instance, one CD's to the location of the BlackvueDaily.exe
Ex. C:\Users\Me\Documents\My exe folder>BlackvueDaily.exe -event -S:\
This would download all the "event" videos from the day to the S drive.
This program may be buggy as I have not tested it extensively. Let me know of any problems or anything that may be worth adding.
