Bluetooth TPMS pressure reset no longer possible?
Dangerous Fish
Pilots the Millennium Milkfloat
2,813
6,848
UK
I've found a few threads about this but no definitive answer.
It doesn't seem possible to 'retrain' the car to lower tyre pressures with the BT sensors. The TPMS reset button is gone now.
I like to run lower tyre pressures than the 42psi recommended (I'm not getting into a debate about whether I should or shouldn't, BTW).
Has anyone found a way to clear the warning and get the system to accept lower pressures?
I'm looking for the answer to this too. Dropped mine to 40. The car seems to take a dislike to just 1 tyre
That's a rounding thing. The actual pressure is probably something like 39.9 (which is >2PSI below recommended) with the rest >40, but they all get rounded to "40" on the display with the one out of range highlighted in yellow.
TPMS sensors can be as much as 1 PSI out from the actual pressure. I use a very accurate motorsport guage to set my pressures and when I put 40.0 PSI in my tyres the TPMS reads "41".
Still haven't found a way to clear the warning, so I suppose I'll have to put up with running higher pressures.
I actually looked at mine today - they are all 35 with one 36, but I do not get a warning. I normally run at 42 but this is a result, I assume, of the recently-cooler temps here. Just haven't had the time to pump them back up.
