Trying to understand more about the part of Starliner that is thrown away. At https://scanalyst.fourmilab.ch/ I found this:
In contrast, Dragon has 16 Draco and 8 Superdraco engines, which of course are not thrown away.
The more I learn about Starliner the more ridiculous it seems; massively more expensive, more complicated, with non-stop problems, from a company that has said it will never again enter into a fixed-price contract because “it doesn’t work for us”. They don’t deserve another penny of our taxpayer dollars.
That is a huge amount of expensive hardware to throw away every time; 52 thrusters! And how can they diagnose the problems when they can never examine the hardware after it’s been used on a mission?…a major difference between Starliner and SpaceX’s Crew Dragon. On Crew Dragon, all of the thrusters used for launch abort, attitude control, and orbital maneuvering are located on the crew capsule and reused for every mission: the Crew Dragon disposable “trunk” section contains only the solar panels, heat radiators, and aerodynamic fins for in-atmosphere aborts. On Starliner, however, the service module contains all of the thrusters except for a small complement on the capsule used solely for re-entry attitude control. There are 20 high thrust maneuvering engines, 28 low thrust attitude control and orbital adjustment thrusters, plus four launch abort engines, all in the service module. Since the service module is jettisoned before re-entry and burns up in the atmosphere, all of this hardware is expended on every Starliner flight. Because the thrusters are not returned to Earth, there will be no opportunity to examine them after the flight to determine the cause(s) of the multiple failures. As SpaceX has said on many occasions, reusability not only reduces cost, it improves reliability since in-flight problems can be diagnosed after vehicle return and components inspected between flights to monitor emerging life-cycle problems.
