BT Streaming Broken on 2018.14.2?
Discussion in 'Model S: User Interface' started by phaphaphooey, May 2, 2018.
  1. phaphaphooey
    phaphaphooey Member
    During the LTE outage yesterday I learned that my BT streaming also does not work. I have a Samsung Galaxy S8 running Oreo and have no problem in any of my other cars. It will stream a second or less of audio and then pause. Restarting the song will only get another second or so of music before it pauses again. Does anyone else have this issue?
  2. GatorGuy
    GatorGuy Member
    Jacksonville
    I have the same problem on my Galaxy S8+ but it happened to me after a phone update instead of anything with the car.
    I got it to play by hitting play on the center console rather than from the phone.
  3. Logan5
    Logan5 Member
    Newton, MA
    I have the same problem, sporadically, with my iPhone X. The workaround is also what Gatorguy described.
  4. Ande
    Ande Member
    Norway
    I have 14.2.
    No such issue, except my music player is set to pause on connection/disconnect of devices, so it's best to press play on car display, rather than Android device.
    Recent updates provided some of the new high quantity BT profiles. We all know how crappy Apple is when it comes to obeying standards. So your best bet may be to use a player that can force a specific connection type... And force it back to A2DP (If Apple allow for such control)
  5. phaphaphooey
    phaphaphooey Member
    Ande: I have an Android so I don't have to worry about Apple's refusal to play well with others. Thank you for the suggestion however.
    Everyone else: I tried to hit play on the console instead of the phone and had the same result. I will try again and report back tomorrow. Thanks everyone for the input.
  6. phaphaphooey
    phaphaphooey Member
    As an update, I had to hit play on the center console several times but did get it to work finally. Would not work from my phone no matter what I did. Thank you everyone for the assistance.
  7. .jg.
    .jg. Member
    Weston Super Mare, England
    I'm on 2018.14.2 and have not noticed any change in the BT streaming behaviour. The car does sometimes lose sight of the phone's media but it did this before the Tesla upgrade. When it does this, I can fix it by pressing play on the phone's music player or by disconnecting/reconnecting BT. (I never have problems with BT for telephone use - I can always make or receive calls)
  8. xceler8tion
    xceler8tion Member
    Same issue here. I have a iPhone 8 Plus. On firmware 2018.16. The song only plays for a second then stops. It doesn't matter if I press play on the console or not.
  9. BigTonyTones
    BigTonyTones Member
    Los Angeles
    Having the same issue here (Samsung Note 8) . Its finicky to get working right. Even hitting the play in the car console doesnt always work.
  10. TheAccuser
    TheAccuser Member
    Cleveland, Ohio, United States
    Same issue on my early VIN 85D. Running Pixel 2 XL. Happened both on Oreo and now P.
  11. BigTonyTones
    BigTonyTones Member
    Los Angeles
    Latest firmware seems to have fixed the bluetooth issue 2018.18.2
  12. TheAccuser
    TheAccuser Member
    Wish I could force an update to 2018.18.2
    If I take it into my service center, can they force it?
  13. BigTonyTones
    BigTonyTones Member
    Los Angeles
    I take it back the issue has not been resolved. Happened to me again today
