Can I cause any harm by switching from Drive to Reverese at < 5mph?
Discussion in 'Model S' started by PhilDavid, Jan 7, 2020.
  1. PhilDavid
    PhilDavid Active Member
    Philadelphia
    Could someone who has knowledge about the internals of the Model S drive train explain if any harm can be caused by switching from Drive to Reverse at less than 5 mph?
    Sometimes when making multi-point turns in tight places I notice the car lets me switch between Drive and Reverse and I wanted to make sure there is no harm to the car when doing this.
    I'm especially concerned after reading about the sub-frame failure thread for the motor mount to make sure I'm not causing any problems by doing this.
    Look forward to any insight on this topic.
  2. Babaron
    Babaron Member
    SW Ohio and west central FL
    Kim from “Like Tesla” on YouTube did a recent video where she demonstrated that very action. The implication was that it was not harmful but I have no direct knowledge that would confirm or refute that assumption.
  3. Ande
    Ande Member
    Norway
    No. You can't
  4. Galinette
    Galinette Member
    Nantes
    • Informative x 2
  5. Rogue Synapse
    Rogue Synapse Member
    Asheville, NC
    Came here to post that link but you beat me to it.
    Long story short, a Model S driver experienced a subframe failure where the motor mount actually sheared off because of changing into drive while still rolling backwards. Well, the failure was probably due to some structural or design flaw, but the stress of the motor bucking was the thing that actually precipitated the failure.
  6. Need
    Need Active Member
    SoCal
    My car won't let me switch to reverse unless I am stopped. I have to do this everyday because I backup onto my driveway. I wonder if it is because I have creep enabled?
  7. PWlakewood
    PWlakewood Active Member
    US
    Same with mine.
  8. powaking
    powaking Member
    Massachusetts
    I'm sure its fine as long as you don't roll back then smash the pedal once in D. I have to back out of my driveway too and while I do put it into D while still rolling <5mph I do ease into the accelerator.
  9. tyler2323
    tyler2323 Banned
    NV AZ CA
    No I don’t think you can cause any damage at all. Now if it was a Porsche and had 1 gear like it does it most likely could. But no transmission usually should mean you won’t have any negative effects
  10. PhilDavid
    Philadelphia
    I have Creep Mode enabled as well and the car absolutely lets me switch between Drive and reveres at less than 5mph and I find this super useful. Of course I'm very gradual with the throttle when switching directions but want to make sure I'm not causing any harm.
  11. PhilDavid
    Philadelphia
    But don't we still have a single gear? And at these low speeds, a transmission would not really be switching anyway or did you mean how the gears would physically need to switch between Drive and reverse in ICE cars?
  12. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    No.
    If there was any danger, tesla would not let you do it.
    Frame failure?
    I'm sure ludicrous mode has nothing to do with it ...
    • Funny x 4
  13. Galinette
    Galinette Member
    Nantes
    Noooo, Tesla would never let you do something that may cause failure, and fix it via OTA update later :)
    • Disagree x 1
  14. kimvellore
    kimvellore Member
    San Jose
    I do that every day and I love that I dont have to hit the brakes nor take the foot of the accelerator. For the level of acceleration the car has the small torque change at <5 mph should contribute to no structural damage.
  15. PhilDavid
    Philadelphia
    And this switching of direction is "safe" for the single gear transmission as well as the mount?
    I ask about the mount because someone explicitly stated about the change of direction contributing to frame the failure.
  16. Hugh Mannity
    Hugh Mannity Mediocre Member
    Calgary, AB
    I suspect this doesn’t cause any harm. Ive done this every day for the past 4 years with my car. There are no “clunks” or grinding sounds or anything after doing it thousands of times.
  17. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Active Member
    Pacific Northwest
    It feels harmless. Can't see how it would be any worse than launching from a standstill.
  18. AMPd
    AMPd Active Member
    Northern California
    Uhhh what? The model s has 1 gear
  19. Big Toys
    Big Toys Member
    Florida
    Keep in mind that you have all that momentum moving one way while the motors are pulling the motor mounts and wheels the other way. If you feel energetic (pun?) you can do the simple math to determine the kinetic energy and momentum of a 4000 lb car moving at 5 mph that needs to be overcome before you even come to a standstill.
  20. SO16
    SO16 Active Member
    MI
    I do it all the time. But I ease the accelerator until direction changes.
